Модель A1419 / EMC 3070 / середина 2017 г. / четырехъядерный процессор Core i5 с тактовой частотой 3,4, 3,5 или 3,8 ГГц, либо Core i7 с частотой 4,2 ГГц архитектуры Kaby Lake (идентификатор iMac18,3) / дисплей Retina 5K. Обращайтесь к более старым руководствам для iMac Intel 27" с дисплеем Retina 5K (конец 2014 и 2015 гг.), так как конструкция системы очень похожа.
CPU Upgrade to 8th Gen Intel
Hello Guys!
Last year I bought a base model iMac 5K and it was working fine for me but my work has intensify and I would like to upgrade the CPU to an i7 and the HDD to and SSD .
My question is: Now that Apple lunched the Eight Gen CPU's in the new Macbook Pro. Can I opt for the 8700K(or any variant of it) instead of the 7700K?
Это хороший вопрос?
Счет 3
Добавить комментарий
3 Ответов
Выбранное решение
Sorry not an option in your system the rest of the systems logic would need to be swapped out as well (which is not practical) your system is based on Kaby Lake the new 8th gen is using Coffee Lake architecture while similar it’s not drop in compatible.
Был ли этот ответ полезен?
Счет 2
hi Alex Castro your imac only upgare to high cpu but only same life and socket
Счет 0
This is possible,It has been done on motherboards from third party vendors, apples logic is no different, What is needed is a patch for the bootloader, or a spoof in the efi and the compatibility fix added to it that was done with z170 motherboards.Whoever does it first will get a ton of rep.For now though if you can get a 7700k, you wont be disappointing, And I wouldn’t hold your breath on anyone in the mac community putting as much trial & error and time into this.(Just saw that its quite a few months old, didnt mean to revive the dead thread).I also swapped in a 7700k from an i5, tricky but rewarding.
Счет 0
1 Комментарий:
Yes its easy on a Windows PC, Mac's are a very different beast! Its just not that easy. Unless you've got the skills to dig deep into the firmware its just not possible!
из
Добавьте свой ответ
Alex Castro буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 3,797
