The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
25вопросов Показать все
Why is my espresso weak AFTER thorough descaling?
My actual model is DeLonghi Bar 41 pump driven espresso/capuccino machine, but could not find this model as a menu option. I recently did a thorough descaling and cleaned the boiler outlet as described in the manual. For descaling, I ran about a half cup of solution through the macjine, paused about 15 min, then repeated about 5 times before running the remaining solution through the machine. After doing this, the espresso is coming out very quickly, tastes weak, and has little or no crema. I'm using the same coffee, same amount, tamping exactly the same way. Is it possible my descaling damaged the machine? Any ideas about what to do next?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I think it might have something to do with your spring tension which might be less causing water to come out with lesser pressure. Open up the diffuser and try and stretch the spring a little bit and reassemble. That should help with the water flow.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Daniel Asta будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 443
