Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
157вопросов Показать все
Touch screen turns white
When I first turn it on it looks fine then the middle of the screen starts turning white. It is still responsive but is hard to read sometimes. When I go to different menus I can see some of the previous text overlap. Picture on Google photos
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
Has there been any water damage to the system? The fading screen can be a sign of that. If not, I recommend tearing the unit apart (using our guide here), cleaning (with isopropyl alcohol) and reseating the bottom screen's ribbon cables. If that does not work, you'll need to replace the screen.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Morgan Babineaux будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 8
За всё время: 218
