Repair information for printers made by Canon.
resetting my ink absorber
I have a Canon Pixma MX420 printer and i'm getting the ink absorber is almost full. I have removed them and cleaned them. Still getting the error. How do I reset it to remove this error?
Это хороший вопрос?
Счет 16
7 Комментариев
On my MG2550 cleaned the absorber sponge and everything like it had to be done. But already tried ALL the POWER-RESET/STOP button ideas. Tried it in service mode with “Service Tool V: 3400 3600 3800 3900 the printing eeprom is working, but in lights test or what I really want absorber counter reset, the programs allways freezed. On the versions 4200 4718 and 4907 the counter reset is earned by a massive 002 error code, so the printer doesn't understand the command. What should I do more?
из
Me too :(
Looking for a solution
из
Throw it in the trash and buy a new printer.
из
I love my MG5220 printer. I actually did buy a new printer (with more features), but I kept this printer. It does some things that the new Canon printer can't do. i.e. auto-detect check size when scanning. Dumb new printer thinks it is auto-detecting, but gets it wrong.
из
never worked for me, i was able to access service mode on m980 but after cleaning ink pad no way would it rest.
из
Показать ещё 2 комментариев
Добавить комментарий
10 Ответов
Выбранное решение
Resetting the waste ink absorber on a Canon printer
1.Make sure the printer is turned off.
2.Press and hold the Resume button (triangle inside a circle).
3.Whilst it is held down, hold down the Power button. The green led light should come on.
4.Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
5.Release the Power button.
6.Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
7.Turn off the printer and then turn it on again
Hopefully this helps
Был ли этот ответ полезен?
Счет 12
18 Комментариев:
I have done this numerous times, I have no green led light. The only light that comes on is the blue copy light
из
Sorry about that, I also looked on the Ifix guide page and can't find your printer model. Hopefully you get it sorted.
из
This absolutely does not help. Pressing the Resume Button (STOP) question is it an Off On situation need to press it on off on off on off on off ? Or just twice. Tried it both ways. I do not get a yellow light step 2-3. Just Blue = on. My printer is an MX890. Canon does not support this printer any more. Sad news for HELPDESK Professionals. I was one for the State of Virginia in the Mental Health VITA, for 23 1/2 years . Cannon Help Desk seems like they are not versed in old equipment or just do not give a %#*@ about customer satisfaction for their products. There must be some old-timer who knows how to clean or reset an Ink Absorber in an MX890 if it is a brainless operation. I need the steps spelled out exactly what the power light does on the four clicks please. I have used tissue to absorb the ink all along the printer track to reduce it being almost full. Resetting the counter would be a blessing. Any one can email me. Appreciate it very much. Thank you.
из
It worked for me. Thanks heaps.
из
First I dig up the rubber pad, cleaned, dried then put the both plastic cover and did the procedure you suggested.
I tried speedytechlive, mine is a canon MX 895, First of all the light is blue unless, I am colour blind. I have tried 20 X , the outcome to these procedure is "Negative:. What to do next, maybe I cleaned the wrong ink absorber. Could you please write a diagram, where the ink absorber is and please explain step by step, that would help. Frustrated Pinky
из
Показать ещё 13 комментариев
For the MG6220: You must reset the Ink absorber counter after cleaning.
1. Download ST_V3600_resetters.exe from Cannon
2. Turn off printer. Start the ST_V3600 on computer connected to printer
3. Holding down the stop button, press the on button. Keep both pressed
4. While holding the on button, press the stop button 5 times. Then release the On button.
5. When Power light is on, the machine is ready for service mode.
6. Run the Test page option from the ST_V3600_resetters.exe program.
7. After it completes, press the Set button by Ink Absorber Counter/ counter Value 0.
Turn off computer
(These instructions re in the MG6220 or MG5220 (almost correct) technical manuals)
Счет 3
6 Комментариев:
My printer is Canon TS8120 so the triangle inside a circle is not visible on my screen
из
How do I fix my problem wit the ink absorbor counter on the TS8120?
из
Trying to find where to download ST_V3600_resetters.exe from - proving very difficult. Any ideas / links?
из
I tried EVERYTHING else for the MG6200 and none worked. For this series printer you can get up to the "hit the cancel button 5 times and let go of the start button and then wait until the BLUE ON light stops blinking and stays lit" part, but then pressing buttons after that does absolutely nothing!
HINT: put a piece of scotch tape on the red triangle in the circle-lit area so you know where to press because there is no actual "physical" button to see... it's just lit up from underneath.
YOU NEED THE RESETTER SOFTWARE!!!!! and THESE instructions using the ST_V3600_resetters.exe FIXED THE PROBLEM!!!!!!!!!!
Of course, the reset software is Windows, so If you are using a Mac, like me, Windows 10 through Parallels software worked fine to fix the problem!
из
Here is the link for a direct download to the resetter:
https://adrianvideoimage.com/wp-content/...
из
Показать ещё 1 комментарий
I followed the instructions here - https://easyfixs.blogspot.com/2019/09/se...
Downloaded and extracted the RAR, ran through the steps to turn on the printer in Service Mode (Canon MG5250 required pressing the STOP button 5 times) and then the software worked. Just pressed the SET Button on the v4720 Service Tool.
Счет 0
4 Комментариев:
Where I can find the ink absorber pads in canon maxify mb2140 to clean them by warm water and soapy? Please explain in detail how to take pads out of printer
Thank you in advance
из
Hi, Maxify MB series have a replaceable service tank in right hand rear corner. You can access it by removing the RH side cover.
из
What service tool can I use to reset the ink observer for canon tr4540
из
when i lunched the tool, my laptop was not responding !
из
Please i need the authentic download link to ST_V3600_resetters.exe. I have been trying to download it.
Thanks to you.
Счет 0
2 Комментариев:
Here is the link for a direct download:
из
Thanks I have downloaded the software but it kept giving error when I click on the "set" or any tab.
из
I will delete and re-install my MG2560 it might work
Счет 0
1 Комментарий:
Bestafternoon afternoon all please I need direct download link of TS704 canon printer resetting tools I have tried downloading it isn't forthcoming
из
Hi, anyone know the secret to a hard reset for 'ink absorber nearly full' message for the Canon MG6360?
I accidentally tilted the printer while trying to remove a paper jam and now i'm always getting this message, %#*@ it.
I have tried other instuctions similar to those for other canon printers about 6 times and none have worked.
Really need to keep this printer as can't really afford the cost of a new one.
Hope someone can help advise, thanks
PS I'm using a iMac and apple software connected to this printer and do not have windows, so I'm after the Mac version of the resetter software if it exists, Thanks
Счет 0
You may not like my answer, but here is what I did on my Prisma 870. I took it apart, many YouTube videos to help with this. You may not want to go this deep.
Then I removed the upper ink absorption pads from the right side base of the machine. These I rinsed in warm water until clean. Then rinsed the lower pads, which I left intact ( too hard to remove), squirting water on them then sucking it out with a wet & dry vacuum, I did this about 10 times. It is incredible how much ink is in the bottom of these machines. Then I reassembled everything.
Next I downloaded the canon utility ST_V3600_resetters (canon site). I hooked my printer to my computer by cable. Then put the printer in service mode. You should easily find an instruction on YouTube on how to put your model in service mode. My computer recognized the printer right away. I then ran the utility program. The utility didn't work 100%. There is an option to set the region, which didn't work for me, so a lot of the text was in Japanese, but not all of it. The block for Ink Absorber Counter and Counter Value was in English. My counter was at the max (I think it was 1000), I set it to zero and hit the set button. Bam, my counter went to zero and the printer was 100% as new. I have been using it the last two months and it is perfect.
I wish I kept a more detailed step by step, but honestly I thought I had little chance of success. I was wrong.
Do a search on ST_V3600_resetters, it easily comes up on the net.
Good Luck!
Rick
Счет 0
1 Комментарий:
Thanks for your reply, however you are to be commended on your dedication to that process, thats sounds messy to me and I do not have a wet and dryvacuumn. Also as I understand it that resetter is windows based which I also don't have. I might just have to bite the bullet and get a new machine i think?
из
AFAIK, you can't reset ink absorber full/almost full errors in most Canon printers just by clicking the buttons. Some models can be reset with Canon service tool, whereas other needs their EEPROM ic chip (where the ink counter information is stored) to be replaced or reprogrammed with chip programmer. I had the same issues with my e410, I tried all methods but to no avail. Finally, I bought pre-programmed EEPROM ic and replaced it, and only then it worked for me.
Счет 0
1 Комментарий:
Buy a new printer.
из
alguem com reset para cano g-7010 ?
Счет 0
How do I reset ink counter of canon TS 704
Счет 0
Добавьте свой ответ
no1crasher буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 54
За последние 7 дней: 382
За последние 30 дней: 2,338
За всё время: 132,783
