Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
678вопросов Показать все
Where can I get parts decently priced?
I've got an iPhone 8 Plus in Red, it's got everything but the screen and battery. The housing is bent and the back is smashed so that needs replacing. I've managed to find all parts I need, except for the camera lens cover, I can find them just not in red! I did find one listing on eBay that has the lens already attached to the glass back, but they won't ship outside of USA which is a problem as i live in NZ..
So is there anywhere else I can get a glass back with lens cover on it, or just the red lens cover? I want to stick with the red just in case i decide to sell it in the future, although I'm planning on using it as my work phone. Or is it possible to just replace the glass lens bit, and i reuse the red frame from this one?
I have mostly been looking on eBay, Aliexpress and TradeMe (nz only equivalent of ebay), but can't find exactly what I'm after.
Any help is greatly appreciated.
Это хороший вопрос?
Оценка 0
1 Комментарий
EDIT: I found a 10 pack on Aliexpress
из
Добавить комментарий
4 Ответов
Выбранное решение
I like to order obscure parts from PhoneLCDWholesale. I believe they have what you're looking for here.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Awesome thank you. I will keep them in mind for future use.
из
Hi Caitlyn, I recommend that you check out Mobile Defenders, they have high quality parts for a reasonable price, I know they carry camera glas lens. You can find them at: www.mobiledefenders.com
Navigate over to the Apple column and choose iPhone 8 Plus. I hope this helps you find what you are looking for, and have a great day!
~Alec
Оценка 0
I believe the 8 plus with the red housing uses a black lens cover, not red. I’m linking you to a parts manufacturer I know. They usually have what I’m looking for. It’s called Gadgetfix. The first link is to thier 8 plus parts. And the second is to the back glass your looking for.
Link 1 parts
Link 2 Back Glass/Lens
Оценка 0
1 Комментарий:
The lens itself is black yes, but its the red frame part that I'm after.
из
Hi Caitlyn, I recommend that you check out CPS : www.cellphonespares.com or www.iphoneLCD.net
Оценка 0
Добавьте свой ответ
Caitlyn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 140
