Hello @abbylww0,
Error 9 is somewhat related to dropped connection.
There is more than one cause that can lead to this failure.
However, if the iPhone was charging normally before, does not have a charging port clogged with pocket lint, and was dropped (causing the screen to break) and bent (or possibly sat on), then you may very likely have a board level failure.
Technically, you may have a failed connection between a component known as the eeprom, and the CPU of the iPhone.
There are 3 popular ways to repair this: #1 reballing the CPU, very risky, very difficult and expensive; #2 drilling the CPU and placing "jumpers" to connect the CPU to the eeprom (risky, difficult, and expensive); #3 heating the CPU and applying pressure at the corner of the CPU where this failure occurs (very risky, could be only a temporary solution, can be cheaper).
Personally, my recommendation would be either to find someone who can offer you a no-fix-no-fee solution consisting of going over a few possible causes such as charging port, Tristar, NAND and NAND voltages, and finally option #2 = drilling the CPU (provided the cost is reasonable for both you and the technician performing the repair), OR discard it and buy a new (or used) phone. We've done option #2 before to retrieve data and were successful most of the times, and the most of those repairs lasted an acceptable amount of time afterwards.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
I had the same problem tried everything then I started just messing around so I took off the screen and tried updating it and it updated but then wouldn’t restart I then connected just the lcd and digitizer connector and left other connector unplugged and it updated and booted and is working fine now 🤷♂️
из Jesse
