Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
stuck on the plug to itunes logo
Its stuck on the plug to itunes and i plugged it into itunes and it gives an error. The error number is 1671. Do you think i will be able to fix it or should i take it to a professional or Apple??
Btw: It happened after my father took it to a guy to put a sim in it a was gonna set it up myself but then he did something to it (i guess he thought i wanted him to set it up or something ) then it popped up and wouldn't go no matter what i tried.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Try using a mac to restore the iphone as this error usually is to do with operating system or outdated software.
1. try to update itunes
2. try using a different system
3. try to use an original apple cable
4. restore the phone if update doesnt work
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you so much im going to try and see if it works :)
из
Наиболее полезный ответ
Some iTunes errors are related to bad cords, and can be worked around by moving to an Apple branded cord. Also, I have one computer where one of the USB ports is temperamental and changing where it's plugged into the computer helps.
Besides that, what's the error number?
Оценка 1
2 Комментариев:
Hello and thanks for your help. The error number is 1671. Do you think i will be able to fix it or should i take it to a professional or Apple??
из
1671 is related to the iTunes client on your desktop being unable to connect to the Apple servers to download software (it's pretty common for iTunes to want to reinstall the OS and/or update to fix an issue).
That shouldn't have anything to do with the connection to the device, and the bad cable/bad USB port angle I was talking about
Here's a pretty comprehensive write-up on dealing with the 1671 error: https://appletoolbox.com/2016/01/error-c...
из
Добавьте свой ответ
Unknown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 72
