The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Stripped screws. ifixit screw extractor not working
Hi I purchased the screw extractor kit to try and get 3 screws that where stripped by Apple when they repaired my screen.
I have tried all the bits but not one has worked for me.
would someone be able to help me with this, I can't clean my mac which I know is dusty inside.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
Выбранное решение
Booked a Genius Bar appointment and they got them out and replaced them for free out of warranty and out of Apple care.
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
If you or a friend have available one of those rotary tools such as a dremel or the likes you can use a round shaped thin cutting tool to create a slot on the screws head and use a flat head driver to get rid of the stripped screws. You have to have a steady hand but with some care you should manage. That's my favorite way to win smaller stripped screws.
Оценка 3
4 Комментариев:
I do and would do that, however I would end up cutting the unibody
из
You could try using a jewelers hand drill with a left hand drill. going slow and easy pop the head of the screw off then use a good jewelers gripping plier slowly twist the shaft off. Often times just the act of drilling will loosen the screw.
из
I have just booked it in to apple and I have to prove that I did not damage them cos this happened after i replaced the screen by apple. I will just say that there is so much dust inside how could I have ever opened it.
из
Apple fixed it today at no charge, changed all the screws over and got the stripped ones out.
из
Добавьте свой ответ
Luca Chana будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 777
