Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
678вопросов Показать все
iPhone 8 Plus touches go crazy (ghost or no) after screen replacement
I have iPhone 8 Plus with broken screen. Have changed it to eTradeSupply screen, after one day the screen gone crazy - there is no touches at times, ghost touches at times, sometime all is good. Original broken (glass) screen was working good. I have tried hard reset and etc. Obvious advice everywhere is to change screen to another one, however there is a little twist -> the screen is perfectly working with out any problems if you open the phone (so the screen part is not closed/connected with the rest of the phone), looks like the flex cable might be a problem (bending?) or is anything else may cause that? Any thoughts?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Check the enclosure for bends. If the screen works perfectly with the phone open, it could be that there’s a bend or dent somewhere in the housing that’s putting undue pressure on the digitizer glass. also ensure that the flex cables aren’t getting kinked when the phone is closed. I have seen this happen before and it is almost always one of those two things happening.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Alexey Demidov будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 4,700
