Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
387вопросов Показать все
Turns on, beeps then shuts off
As the title states, I’ve unplugged it and plugged it again and it has the same result everytime, the blue light comes on for about a second, has the initial start up beep then shuts off right afterwards. Is there anything i can specifically check or something i need to replace?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Many PS4 users have encountered this issue. There are several things that you can try in order to get it working. If either of these work they probably won't work for a long period of time but they might.
1) Unplug the cord from the back and plug it all the way back in, making sure it's fully seated. Also, if you're using a power strip you might want to try plugging it directly into a wall outlet.
2) You can try turning it up on it's side. This usually won't work, but it does sometimes...it's worth a try.
3) Another thing to try is hitting it against your knee or the floor. Not hard enough to break anything (obviously!) but enough to give it a bit of a jar. This method probably works more than the first method, but is not a sure thing either.
These are the first things to try. If neither of them work then you'll probably have to take it to a repair shop or send it in to one.
I hope it will be helpful. Good luck.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Saul Requena будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 601
