A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239вопросов Показать все
Where is the fuse location on the board for mac pro A1706 backlight?
my a1706 mac book pro has no backlight, i can see apple logo on the screen with flash light. trying to check the back light fuse before i go to apple store for expensive repair.
But i don’t know where that fuse is located on the board. If anyone has that layout please help me
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
@mdesai7482 the backlight fuse is a 3A 32V in a 0603 package
Был ли этот ответ полезен?
Оценка 0
11 Комментариев:
@oldturkey03 Thanks but no luck fuse is ok. still have same issue.
из
@mdesai7482 if you have experience with board level repair you could trace your backlight circuit. If yo do not I suggest you contact those active users on here that do have the expertise and tools to do this for you. @tcrs_circuit in the USA @reecee in the UK and possibly even @refectio in Canada @arbaman in Sardinia (Italy) ;-) @rany in Lebanon and many others
из
Thanks
Do you know where is the connector for the backlight?
из
@mdesai7482 I do not quite follow you with that. What kind of connector? What is on your mind....?
из
Sorry, I mean any connector that relates with backlight, through which it gets signals from motherboard.
i don't have diagram so trying to trace the circuit of backlight.
or clean that connector see what happens. otherwise apple gave me estimate of $450 to fix it.
из
Показать 6 больше комментариев
Наиболее полезный ответ
Backlight failure other than the screen on these is rare. Fuse failures are almost non existent unless you plug the screen in with power. It is probably a LCD issue. Of course if you have obvious corrosion on the board, address that before blaming the LCD. I’d put my money on the LCD though.
Оценка 1
1 Комментарий:
Since am also facing this issue, I have checked with the New screen, Still no luck. and also Fuse is okay, May I know where is the backlight IC located?
Sorry for the bad English!
из
Know this is old. But for future searchers.
Apple is offering a 5 year repair window on these, due to backlight cable wearing out prematurely. (apparently, just a little too short)
https://support.apple.com/13-inch-macboo...
and for do it your selfers with skills who just missed the warranty period…
MacBook Pro Retina (2016-2019) Display Backlight Cables
MacBook Pro Retina (2016-2019) Display Backlight Cables Изображение
Продукт
$19.99
Оценка 0
Добавьте свой ответ
manish будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 40
За всё время: 3,697
