The Samsung Galaxy S5 Sport is Sprint-exclusive and designed for fitness enthusiasts.
23вопросов Показать все
Can only get internet through WiFi not conneting to 4G
I was out of the country for 10 weeks and used an Italian Sim card. I replaced it on the plane home with my U.S. sim and it worked that night but the next day I was unable to connect to the internet. I can only use wifi and can’t get 4G. I’ve turned off my phone re inserted the sim and battery. and restarted. Nothing has helped. Help!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Who is your service provider? I expect you need to contact them and see if they can help with that. Every version of android is a little bit different so without knowing that it may be hard for the service provider to help you as well…. So be sure to look that up under “settings->about phone” before you talk to them.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
lindajordan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 36
