Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Broken Home button after screen replacement
I was able to successfully change my broken screen with the replacement screen, but when I turned the phone back on I noticed that my home button wasn’t working anymore it felt a little wobbly as well, I reopened the phone again to check if any of the cables were cracked but I saw nothing out of the ordinary, I tried to setup the iphone without the home button but I ended up on a “Press home to upgrade screen” now I can’t get out of it and when I try to connect it to Itune my computer can’t even recognize the phone.
Do you have any ways to get past this screen or be able to fix the home button?
Thank you
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi,
You should try another button. If it still doesn’t work, you might have damaged the ribbon cable that goes behind the metal plate. Try replacing that also.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Agustin Lopez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 186
