Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
678вопросов Показать все
iPhone 8 plus no service(sim card can't read) after water damage
iphone 8 plus no service(sim card can’t read) after water damage
Hello all how are you?
Dropped iphone 8 plus into the water then I cleaned mother board by alcohol
everything works fine except no service network carrier
i think something wrong with cellular antenna
which part i need to replace?
maybe charging port? thanks all
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
There are a few antennas being used (mainly the antenna cables near the charging port are used for cellular 3g/4g) and a few things you should check is if imei is displayed when dialing *#06#, also modem firmware and imei displayed in settings > general > about phone.
I would expect some board-level repairs needing to be done after liquid damage.
I recommend taking the phone to a reputable repair shop that does board-level / liquid damage repairs for liquid damage evaluation.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
My phone does the same thing but not water damage. It connects to wifi but that's all it says no service
из
I have a few of these as well, liquid damage that shows no modem firmware after but everything else works.
из
Добавьте свой ответ
Kyuho Lee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,494
