Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
429вопросов Показать все
Headphone/External Speaker Jack stopped working
I had powered Altec Lansing speakers hooked up to my 24" iMac and they worked fine for ~1 year. I recently upgraded my RAM with no difficulty, however afterwards, the headphone jack no longer recognized the presence of the external speakers. The sound preferences panel "output" tab shows "Internal Speakers" and "Built-in Output" regardless of whether the external speakers are plugged in or not. Rarely and for a moment, if I plug and unplug the speakers from the headphone jack, the sound panel occasionally shows "Digital Out" but still no sound and it quickly reverts back to "Internal Speakers." Any thoughts?
Это хороший вопрос?
Оценка 9
2 Комментариев
I have tried everything mentioned here and nothing works. I have used speakers connected through the headphone jack for years until today. No audio/headphone out shown, only internal speakers. This with the speakers connected and they differently work fine.
I am using a iMac 21.5 mid 2011.
из
I used my 2008 iMac for 14 years with altec external speakers, and then one day out of the blue the jack stopped working. It wouldn't work with headphones either. That was the straw that broke the computer. Now I've got a new iMac and frankly I'm afraid to plug in the external speakers! Perhaps I'll try to purchase some apple branded ones?
из
Добавить комментарий
8 Ответов
Наиболее полезный ответ
Guess what you will notice on the internal input that earphones are not listed. So to activate the earphones on a MacPro the device (earphones) must be connected before it to show up in the internal input - go figure!
Thats how I got my earphones to finally work on my MacPro.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
This solved a problem I've had a long time. Thanks!!!
из
Worked for me too! Thanks!
из
thanks George, worked for me, too! found it in audio settings that external output was muted for external speakers somehow. they were working fine for days...either way, all good to go here now.
из
Thank you George - LOL I cant believe I didnt work that one out - Yes after an hour of trying to troubleshoot this issue, as soon as I plugged the Speakers back in the headphones option appeared in the Sound Settings and it was in fact muted.
Оценка 2
3 Комментариев:
I was sure (based on my trouble shooting) that I had a bad headphone (external speaker) jack on my iMac. But, then I read the above... So, I plugged in the external speaker cable and checked the Sound Settings, ... Sure enough - It was Muted! How and why? - I don't know. Likely some Apple system software update.
из
Thank You! George and Joh
из
Mine wasn't muted but the volume was at the extreme low. All by itself it decided to go totally low as in "OFF"!!
из
Well, this isn't a fix per se to the problem of the malfunctioning headphone jack, but it is a workaround which allows you to continue using your external speakers for all Mac sound output.
This fix requires obtaining a piece of hardware, namely an Airport Express with sound output. According to Apple, this device can only stream sound out from iTunes. However, with two pieces of open source software, this situation can be changed to allow all Mac sounds to be routed through the Airport Express. The two pieces of software are soundflower and the other is RaopX. Description of how to get and intstall each is available at http://www.hersson.net/projects/raopx, and as best as I can tell, they work well.
You're still left with a malfunctioning headport jack, but you have full access to the highest quality sound that you wish to expend your $$ on relative to the speakers you buy.
So, work around, but not true fix
Оценка 1
1 Комментарий:
The url link to www.hersson.net is broken.
из
This thread is a year old, but since it still comes up in a search I'll give my February 2012 advice:
Computer: iMac 27" Intel based all in one
Issue: Internal speakers work; headphone jack does not.
Seems to me, it is easy to bend the inside connectors, fry the jack itself or otherwise simply break it. You can click all the settings, preferences, and MIDI controls you want - it will not correct the problem. You're a Mac user, you know you have tried all the settings and are second guessing your own expertise. So here's the problem: your headphone audio jack is cooked. Get over it.
Solution #1 (expensive): take it to an Apple store.
Solution #2 (inexpensive): get a USB to stereo audio input off Ebay for $2.00, wait 3 weeks for it arrive from Hong Kong and use your headphones through it.
Оценка 1
2 Комментариев:
audio output is damaged , jack is not fitting any more : if I go for solution #2 please advise what to buy : male USB to female minijack ? (not available?) how to use on my imac ? how readdress audio to USB output instead of audio output ?
thnks in advance
из
Me the same; Headphone jack and inline jack both u/s on my iMac 27" best part is they both very rarely used just goes to show what lack of attention to detail on this prestigious piece of kit!!! cheap $@$*!! - I'd sack the @%^$$@$# who designed this, why didn't they put these vulnerable parts on a removable section?? hang on!! no! make it more difficult? we make more money!! yeah its called Greed! what comes around -- goes around!!
из
FIXED! I tried everything and was beginning to believe that the headphone jack was just broken. But, I'm thinking -- I hardly ever even USE it?!!? How??
So I rebooted, and tried all the above solutions and nothing.
Just for the !&&* of it, I just added a bluetooth speaker (DJKnight Magicbox II) -- As soon as the device was paired -- BAM the headphones showed up.
This just happened after an OS update, so it's NOT hardware or a worn out jack. This is definitely a bug. Adding a bluetooth speaker is just a work-around -- but it works and it's free.
Hope that helps.
Good luck!
Оценка 1
1 Комментарий:
Finally! Thank you John Wolf!! Got so tired of suggestions to try different headphones etc. Based on your suggestion, I paired a set of Bluetooth headphones. Within 15 sec. the output jack was working again. This never would have occurred to me. Of course, I would have had to resort to a bluetooth device, but probably wouldn't have tried the output jack again. Thank you!
из
Have you tried a pair of headphones or a different set of speakers in the headphone jack? If headphones work in the jack and you get the "Headphones" listing in the Sound panel, then the problem may be with your speakers or the speaker plug rather than the computer.
Another possibility -- could "Built-In Output" you're seeing be referring to the headphone jack? I think your computer has only one audio out, so it might not have separate listings for "Headphones" and "Line Out." If that's the case, maybe click on that listing to see what the setting of the output volume is. Maybe it's muted?
If the problem ends up being the headphone jack on the computer itself and you're leery of attempting a repair, an alternative might be to get a USB to Mini adapter like the iMic. But I'd highly recommend confirming that your speakers work with another machine first.
Оценка 0
1 Комментарий:
I have tried plugging a variety of things into the headphone jack -- several sets of headphones and several types of speakers -- all with no effect. And all of them are confirmed to work on other systems (i.e. iPod out).
It is definitely not muted. I get fine sound coming out of the internal speakers (even when something is plugged into the headphone/speaker jack in the back)
из
Having the same problem - the only output choice that appears is "Internal Speakers" - though hitting the ? button in the sound preferences box gets me this :
"Select a device for sound output
To listen through your computer’s built-in speakers, select Internal Speaker.
To listen through your display’s built-in speakers, select Display Audio.
To listen through speakers or headphones that are connected to the headphone jack, select Headphones.
To listen through external USB speakers, select your speakers from the list.
To listen through another audio interface, select it from the list."
BUT there is no other choice listed except "internal speakers"
Оценка 0
I have definietly the same problem like Ken, everything seems to be ok, even the output jack doesn't seem to be damaged. It's probably a software problem. Does anybody have an idea how to fix this?
Andre
<I have tried plugging a variety of things into the headphone jack -- several sets of headphones and several types of speakers -- all with no effect. And all of them are confirmed to work on other systems (i.e. iPod out). It is definitely not muted. I get fine sound coming out of the internal speakers (even when something is plugged into the headphone/speaker jack in the back)
Ken, Jan 8 2010 @ 8:38 PM>
Оценка 0
Добавьте свой ответ
Ken будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 33,672
