Complete disassembly and installation guides for most iPods, including the iPod Classic, Mini, Shuffle, Nano, and Touch.
6221вопросов Показать все
Вопрос закрыт
How to place the Front Panel Replacement correctly
I've succesfully take apart the front panel assembly but I can't place the new one correctly. The top of the screen, which is near the front camera, it is not well attached. It takes off and cannot find a a way to insert it . I guess the problem is this piece of metal http://www.skymac.com.ar/ipodtouch.jpg
Are there some tips to keep in mind?
Это хороший вопрос?
Оценка 0
1 Комментарий
The guides available only show the procedure to open and remove the parts do not indicate how to put the new one, and not always reassembling the device is in reverse order.
In this case, the touchscreen flex was the problem, it was folded up against the metal plate where the LCD is inserted, preventing this to be correctly seated. The cable must be placed so carefully folded so that it is right beside the front camera.
The pictures are not good just like my poor english. Somebody could put this tip in the correct guide to help others.
Thank you
http://www.skymac.com.ar/IMG_0270.jpg
из
Добавить комментарий
2 Ответов
Выбранное решение
The guides available only show the procedure to open and remove the parts do not indicate how to put the new one, and not always reassembling the device is in reverse order. In this case, the touchscreen flex was the problem, it was folded up against the metal plate where the LCD is inserted, preventing this to be correctly seated. The cable must be placed so carefully folded so that it is right beside the front camera. The pictures are not good sorry.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
good job ;-)
из
Наиболее полезный ответ
macpatagon, I am not sure which iPod you have but based on the picture you attached it is an iPod touch. My best advice to you would be to study the manuals on here and see what you get. These instructions are proven and do work. As always, study the material and take a good luck at what you got. Have a clean and uncluttered work area and take your time when you do it. Good Luck
Оценка 1
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 696
