iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
873вопросов Показать все
iPhone 8 was stuck at 1% now won’t come on.
So I got a phone with a report from one of my techs. The report said after a battery change the phone was stuck at one percent, thinking it was a defective battery she changed it again and now the device will not power on. Screen tests fine, batteries tests fine, charging port tests fine. I trust the tech to be honest and I did find an answer for the “Stuck at 1%” issue. I looked at the component the post directed me to and it was pulled from the board but I also noticed another chip that was broken. A silver like chip just to the left of the RV3C002UN chip by the battery connector port. I can’t find what component this is without a schematic and I cannot find the schematic. Could anyone help me find the name/number of the silver component?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
из
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
из
Were you ever able to identify the name of that shiny glass component?
из
Добавьте свой ответ
Blaked89 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 11
За всё время: 573
