Trackpad: cursor not moving
Got used logic board from ebay and D5802 diode in the booster circuit for trackpad was missing.
Got one from the donor board, soldered in, somewhat it’s now better (trackpad now poorly reacts on taps but still no solid cursor movement), i’ve measured the voltage on the output of this D5802 and it’s only ~11V instead of 18V. It could be i’ve killed it during de-soldering from the donor board, but i suspect it’s either some cap or a resistor gone bad in that booster circuit. The problem is that most of them are covered by the trackpad connector so i can’t measure the voltage in there, and if you unplug the connector there’s no voltage…Anyone can give me a hint please?
thanks in advance.
Update (08/24/2018)
trackpad itself is OK, i’ve tested it on another logic board.
the issue is with this particular logic board’s booster circuit . I’ve inserted the relative portion of the schematics and marked the D5802 diode in question.
Это хороший вопрос?
Счет 0
1 Комментарий
Want is your board number?
из
Добавить комментарий
1 ответ
Выбранное решение
I tend not to spend time trying to fix the trackpads as often the reson they have problems is liquid damage. I just replace them MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a trackpad compatible with the Mid 2009 to Mid 2012 model A1286 MacBook Pro 15 inch Unibody laptop. Part #922-9035, 922-9306, 922-9749. Изображение
Товар
$43.99
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Nurfed Igvaar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 323
За всё время: 432
