Repair guides for displays (or monitors) for computers or other devices with video output.
505вопросов Показать все
HP desktop display shows for 2 seconds then shuts off
So I have an HP desktop display that comes on for about 2 seconds then seems to dim and lose its connection to the PC showing the display details in what looks to be minimal brightness then shuts down in about the same time frame
I tried many things (known-good cables, different PC, picture does show normally for a few seconds so I don’t think it’s the backlight, tried to change settings but it powers down before I can, etc.) and believe I narrowed it down to the power supply circuit board. I would like a second opinion but that’s what my diagnosis would be. Could anyone else give me some input as to what else I should try before having to change the whole board or the components on the board?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
@blaked89
depending on the exact model number, a failed power supply can do this. Check for leaking caps etc. I have seen it where the video board was faulty and turned off the power board, but far less common than a bad power board.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Dang it, I was hoping it was something simple I missed lol
That sounds like the problem to me too, I’ll start testing and see what I can find.
Thanks again.
из
Добавьте свой ответ
Blaked89 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 627
