Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
Not charging, only recognizing plugged in and stops
I plug in the charger. The device recognized that it was plugged in but only blinks orange a few times, shows low battery on the screen(no lightning) and then screen goes black and the orange light is no longer on as if it's not plugged in.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It seems your cable may be faulty try to change the cable of your charger but make sure you select correct range of products.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jolene буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 386
