2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561вопросов Показать все
"Battery health" keeps fluctuating on brand-new battery?
Just replaced the battery in my MacbookPro A1398 (Mid 2012 Retina).
The new battery initially showed 105% health, but after “calibration” as suggested (drain till shutdown and charge 100% again), it only shows 90% health - in fact it kind oscillates between 88-91%. Again this is health, not max charge %%. The cycle count is still 0 after calibration.
Is this normal ? Or is it a sign of a problem replacement battery ?
Это хороший вопрос?
Оценка 1
2 Комментариев
Who's battery did you install?
из
I used the battery from the FixIt kit I received a week ago, the manufacture date is reported as April 17, 2017. The number on the battery is listed as D865256Q1RGMOKAP.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Download, install and run Coconut Battery to get a much clearer idea of the status of your battery. Then let us know your results.
https://www.coconut-flavour.com/coconutb...
Был ли этот ответ полезен?
Оценка 1
4 Комментариев:
Thank you. I am using Battery Health utility which on the surface does exactly the same thing as Coconut Battery. I presume they both use the same internal system APIs - is it correct ?
Also Coconut Battery seems to require MacOS 10.11 and later, I have to stick to 10.10.5 for a number of reasons.
из
Right below where it says to purchase Coconut Batter Plus the is a link to Older Versions
из
Thank you - I should have paid more attention.
I downloaded and ran - and yes, it reports exactly the same number and behavior as my previous tool.
из
I think you'll need to talk with the IFIXIT store to see if they can ship you out a replacement battery. That way you can double check if the battery is the issue or something within SMC services on the logic board thats doing strange things.
из
Добавьте свой ответ
Alex Miro будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 333
