Rewiring a motor for 110 volts from 220 volt
Hi
I have a NutriBullet purchased in Dubai, designed to work on 220v system
Would like to convert to 110v operation in USA.
Rewiring would be easy if I knew which wires to reconnect.
Mel
Это хороший вопрос?
1 Комментарий
I thought that the wiring of the phases are in series for the 220 volt and I just have to change it to a parrellel connection. A simple change if someone could verify that the motor will turn in the same direction as the original design.
Mel (Original POSER)
из Melvin Siedman
