The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299вопросов Показать все
WiFi barely working after screen replacement
I recently replaced the screen on a original iPad Air. Everything seemed to go good, but now the WiFi works, but just very,very slow. The WiFi signal shows full strength. Could I have damaged the WiFi antennas by accident and why would it show full signal?
thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
The antenna wouldn’t slow the wifi, especially if you’re consistently getting a strong connection. Try resetting your modem or router.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
All other WiFi devices are working fine so it’s not the modem or router.
из
Well turns out the iPad was restricted by a device called circle uaedmfor monitoring use.
Its our sons iPad. We reset that and it now works fine.
Оценка 0
Добавьте свой ответ
Tim Stevens будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 8
За всё время: 119
