Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
121вопросов Показать все
Вопрос закрыт
Post Display Replacement, what would cause the computer not to boot?
PowerBook G4 Aluminum 17" 22 1-1.67 GHz
Hello,
I just followed the guide to replace the display on the PBG4 17", prior to this replacement the computer was working fine(both on battery and A/C) connected to an external display.
I checked the logic board connector and the keyboard connector, tired re-seating them both, twice. If i pull the battery out and the A/C adapter, then put them both back it the light is amber. I then hit the power button and the light turns green, but nothing happens. It seems clear that the battery is getting charged, which I guess indicates it's not the DC-in?
I'm stumped.
Any suggestions as to what i could have done by accident, would be great.
Это хороший вопрос?
Оценка 0
1 Комментарий
Thanks for the responses and suggestions. After spending a good 2-3 hours checking cables against photos from guides, I'm not sure what I did. I tried the PMU suggestions, with no luck.
Not sure how to jump the logic board, but I probably just better call this a total fail and try to recoup some money for the parts.
из
Добавить комментарий
2 Ответов
Выбранное решение
Six hours and no answer. Maybe that's because there is no easy answer. Obviously you have done something wrong. I would take it completely down and rebuild it from the point that you got deepest into the machine. You've missed something or connected something incorrectly.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Thanks! i think i might have muffed the keyboard cable now that I took the entire thing apart. There is a small rip in it. Is there anyway to boot without keyboard as just a test?
из
jump the contact points on the logic board with an inscription POWER BUTTON written aside of the contact points
из
Hi there...
Thought I'd 'chime-in' with this little thought of remedy.
(After) you've checked that every connector, every screw and everything ELSE is firmly and correctly placed, try this...
Replace the C-MOS battery.
I know it might sound too simple, but that's happened to me more often than you'd think!
IF that doesn't work, try a factory re-set of the CMOS pages (revert to factory setting) to see what that does for you.
If that's doesn't help, then there's a possibility that something else may be not connected correctly. Go over everything once more (patience) and I'm sure you'll discover the small error...
Good Luck
P2 of BORG
Оценка 0
2 Комментариев:
Borg - in the Mac world a cmos battery is refered to as a PRAM battery
из
Thank you...
из
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 679
