Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
103вопросов Показать все
JBL red light, and is not turning on!
Hello!
after using the JBL for 7 hours, it stopped working and turned on a flashing red led on the bottom of the box! I can’t turn on and i can’t turn off! it only turn off when the battery runs out, and when I put it to charge it does not turn on and continues with the red led lit on the bottom! Anybody know? thank you!
Это хороший вопрос?
Оценка 3
2 Комментариев
I fixed the issue on my Extreme2 but holding the power and volume + buttons down at the same time until I heard a response. The response I got was the same sound you hear when you are trying to raise the volume and are already at top end….. I powered down the unit and when I turned it on problem solved….. I had read various accounts/remedies online as well and was grasping at straws when I got this routine to work for me….
из
well, i changed the battery pack, 2yo. thinking probable cause
my unit powers up, plays for 5 seconds then i get a red blinking light an it powers off.
tried all the fixes quoted here
any ideas as to what next would be appreciated. thx
4 minutes ago by matthewroche
из
Добавить комментарий
7 Ответов
Наиболее полезный ответ
Hello!
Did you solve it? I have The same problem
Thank you.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
My jbl flip 5 has all of the lights on and i tried to factory reset it but it’s not working i’ve tried turning it off and still won’t work
из
Hold and press power button for 20 sec
Оценка 2
1 Комментарий:
I did that but still won't go off
из
I have similar issue flashing red wont turn on or off but no power won't charge is this broken please
Оценка 1
1 Комментарий:
did you ever fix your problem?
из
I have an Xtreme 2 and this happened to me while attempting to activate “low frequency mode". However my speaker was plugged into the wall when it happened, I simply just unplugged it and plugged it back in and it turned back on. Try plugging it in if it wasn't already plugged in.
Оценка 0
dude i have same on charge 3 i wanted to charge that bad boy when he was on 2 line and i checked after 2 h and still 3 rd indicator was blinking then unpluged and continiued same i drained battery with phone charger and red shows up after dying gets little energy with charger and continiues red blinking after unplug too i think charging board or some $@$* like that bro im confused mine is not that old yet 2 months only :/
if u get something tell me too
Оценка 0
1 Комментарий:
I also have this problem with my jbl xtreme speaker. It has only been played maybe 40 times for a few hours in 2 years!
из
has anyone solved this issue yet? I have the same problem.
Оценка 0
My JBL boom box 2 has a with and red and white light after attempting to put it in low frequency mode and now it won’t turn on or off
Оценка 0
Добавьте свой ответ
Raphael Morishita будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 30
За последние 30 дней: 137
За всё время: 16,934
