A Toshiba laptop released September 2016, Identification Number C50D-A
Вопросов 9 Показать все
Help! Toshiba C50D-A Missing Windows 7 Drivers
I've recently purchased a Satellite C50D-A-11Q and back-spec'd it to Windows 7 64 bit. Unfortunately; there are two drivers which, despite hours of searching, I cannot find. One is the Universal Serial Bus (USB) Controller and the other is the graphics driver. I've been in device manager and discovered that the Graphics Chipset is an AMD Radeon HD 7310 and the USB Controller is an AMD FCH USB XHCI Controller. However the correct drivers still elude me. Any suggestions gratefully received.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Hi ron.atkinson
Just curious on why you need to downgrade to windows 7?
most users should be moving on to windows 10 now.
you can try searching the device driver by using the hardware IDs
example
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I need to downgrade for my job. The software I use is Win 7 specific. I’ve looked in Hardware ID’s but everywhere I look the specific drivers can’t be found :-(
из
Добавьте свой ответ
ron.atkinson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 368
