A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
Это хороший вопрос?
Это хороший вопрос?
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
Был ли этот ответ полезен?
За последние 24 часов: 3
За последние 7 дней: 13
За последние 30 дней: 57
За всё время: 5,413
