phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
Это хороший вопрос?
Это хороший вопрос?
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
Был ли этот ответ полезен?
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
To take a look on battery terminal if a well connected second to check life of battery
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
Phone is not power on and showing logo
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 2,942
1 Комментарий
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
из gharib mahmoud
