Won't charge after screen replacement
So I broke my iPhone 7 Plus screen a while back and figured it be cheaper to replace it myself, plus I could swap everything into a red housing and get a new battery while I’m at it for the same cost of just the screen from the Apple store. The screen was an original Apple LCD that had the glass replaced, and the battery was aftermarket. I got all the parts and tested just the new screen at first and it worked perfect, so then I went ahead to swap everything into the new housing. I didn’t test charging at that point but I basically swapped everything into the new housing with the original battery and when I tried to power it up and it wouldn’t boot. I think I damaged the little battery connector when I was taking it out.
So then I put in the aftermarket battery and it booted perfectly, but whenever I’d plug it in to charge, it’d give me the “This accessory may not be supported” message. I was at iOS 10 at that point and knew about the lawsuit or whatever and updated to iOS 11 most recent and still didn’t fix it. So I got a used original battery with the Apple logo on it and tried that and STILL giving me the message, now with everything original Apple parts. So then I was thinking “hmm.. maybe I damaged the lightning cable connector when swapping it into the new case.” So I just got a new lightning cable connector but its not original Apple and will still charge for a split second then stop and say the “This accessory may not be supported” message.
I really just want my phone back, is there anyway I can still fix it myself? Is there some red flag that sets off whenever non-apple parts are put in and then you HAVE to bring it to the store?
Это хороший вопрос?
