Turns on but screen doesn't
My hp mini 210 turn on but screen is blank
Это хороший вопрос?
I think these had a common problem with the ribbon that connects the screen in the top half to the motherboard in the bottom half… if I'm thinking about the same netbook u needed to replace the ribbon to get it to work properly or fiddle with it and squeeze it etc to get it to work temporarily
Basically try replacing the ribbon it's quite a fiddly job though
Был ли этот ответ полезен?
Can you give me a link to where I can buy one?
Test ram in my experience when ram is not functioning well it will turn on without screen .
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 1,368
7 Комментариев
Can you give us some more details about what you might have done to your device to cause it do this?
из mikeyd123
Hi @magicjet_
Any beeps or pattern LED flashing?
when you power on the computer, observe on the HDD LED if there is any activity.
when you hook to an external display.... do you get display?
you might need to invoke some key to project out to the external display.
else
another test you can do is to test with another known working RAM first
HP Mini 210 RAM Replacement
из Augustine
I have done all of those things.
из Jen
Hi @magicjet_ ,
Do you get a display showing on an external monitor connected to your laptop via the vga port, when you press the F4 key, when the laptop has been turned on and presumably booted into Windows?
из jayeff
No It doesn't do anything
из Jen
Показать 2 больше комментариев
