double ssd in MacBook Pro 2012
Hello friends. two days ago I decided to install another SSD on my mac because I'm a dj and I work with a lot of music. ok this is the case. buy a caddy to remove the cd drive and install the new solid disk that is a samsung evo 860 of 500gb that I also have as main disk. When doing the whole process, the computer does not read the SSD that is in the CD unit. Try to install the factory HHD with the caddy and you will not read it either. What can be? my model is A1278 indentifier 9.2. I wait for your help. Thank you.
Это хороший вопрос?
3 Комментариев
@danj Ideas?
из [deleted]
Who's carrier did you use?
You are sure you have a 2012 13" MacBook Pro? Please double check.
Here are the models within your series MacBookPro9,2. Which one is yours?
из Dan
MacBook Pro (13-inch, Mid 2012)
2.5 GHz Intel Core i5
16 GB 1600 MHz DDR3
Intel HD Graphics 4000 1536 MB
из roberto delgado
