The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465вопросов Показать все
Swapping Logic board with a upgraded board.
Howdy,
I have a macbook air 2013 (6,2). It wont turn on. I took it to a repair shop and they confirmed the logic board is bad. The last 4 digits of the serial number is FKYQ. The macbook air has a 1.3 GHz Core i5 (I5-4250U) with 4gb of ram. I was checking http://www.powerbookmedic.com and found logic boards with more ram and higher clock speeds.
Is it possible to upgrade the logic board to one of the following?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Yes, the ones you linked are all exactly the same board model 820-3437 and can fit your MBA, you can choose for replacement whichever you prefer among them.
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
If you can swing it go with the faster and deeper RAM board (1.7 GHz & 8 GB).
из
Добавьте свой ответ
Qubert будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 224
