Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
207вопросов Показать все
Fan keeps falling over
Hi can someone help I don't keep to good so I have a tall cooling fan at my bed its on 24/7 over the last month it keeps falling over and the tilt keeps dropping down it as if the fan bit is to heavy for the stand. Thank you Susan
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi,
What is make and model number of the fan?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
In addition to what Dave said, if the pole is wobbly on the stand, there is usually a threaded nut on the bottom of the stand where the pole goes through it. This nut may have loosened up due to vibrations from the fan. Tighten it up.
Был ли этот ответ полезен?
Оценка 3
Is there a knob on the side of where the fan connects to the stand? If there is try putting it in the position you want and tighten it until the fan stays put. Or, you could fabricate a secondary stand for it to hold it up where you like it to point.
Оценка 1
Добавьте свой ответ
susangillan35 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 42
За последние 30 дней: 158
За всё время: 3,546
