2.26 or 2.4 GHz / White plastic unibody enclosure
645вопросов Показать все
The sleep indicator light turns on when power is pressed
The sleep indicator light is solid when you press the power button, the machine restarts automatically, then the sleep light flashes once, the machine has no display, the display doesn’t turn on, it does this with ram, without ram, with battery and without a battery, any help appreciated
Это хороший вопрос?
Оценка 0
1 Комментарий
I think it’s the MagSafe board, duh, the battery doesn’t charge and the light stays green, that might make sense
из
Добавить комментарий
3 Ответов
Выбранное решение
I went ahead and replaced the logic board and the machine definitely works with no issues now
Был ли этот ответ полезен?
Оценка 0
Наиболее полезный ответ
Way to much guessing going on here. First thing to do is verify what machine you actually have and we can see what the know issues are. The model you have listed did not have the nVidia GPU issue. Go to this link and insert your serial number and report back what you have. Next do you have any history on this machine?
Do you have another Mac or another mag-safe adapter?
https://everymac.com/ultimate-mac-lookup...
Оценка 2
1 Комментарий:
I have both another MagSafe adapter and another Mac, the charger is fine, it is the late 2009 unibody model MC207LL/A, and as for the history, it has never been in contact with water however it has been dropped a couple times but remained functional afterwards
из
This might very well be a problem with the MagSafe DC in board. I suggest replacing it.MacBook Unibody Model A1342 MagSafe Board Replacement
MacBook Unibody (A1342) MagSafe DC-In Board
Update (10/10/2018)
@coreycusick It appears that getting a new Logic Board would be a good idea. iFixit sells the Logic Board you will need for this Mac for about 100 USD. Very reasonable!
MacBook Unibody (A1342) 2.26 GHz Logic Board
MacBook Unibody Model A1342 Logic Board Replacement
MacBook Unibody (A1342) 2.26 GHz Logic Board Изображение
Продукт
$29.99
MacBook Unibody (A1342) MagSafe DC-In Board Изображение
Продукт
$19.99
MacBook Unibody Model A1342 Logic Board Изображение
Инструкция
Сложность:
Сложно
40 minutes - 2 hours
MacBook Unibody Model A1342 MagSafe Board Изображение
Инструкция
Сложность:
Модерировать
10 - 30 minutes
Оценка 0
6 Комментариев:
Yeah I don’t know why that didn’t click, I already have another MagSafe board I will try and will go from there. I’ll post later to see if the issue is resolved
из
@coreycusick Sounds like a plan!
из
It appears to be a logic board issue, dang it
из
@coreycusick Phooey! Maybe @danj @mayer knows os some other troubleshooting before we conclude it to the Logic Board.
из
Yeah, I can only assume it’s the logic board or a power issue, just because of what the MacBook does, normally I don’t have this much trouble as I have fixed far worse than this, but I’ve never owned this model until a couple days ago and this particular issue seems to be a faulty NVIDIA GPU
из
Показать 1 больше комментариев
Добавьте свой ответ
Corey Cusick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 395
