Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Home Button and Touch ID not functioning
So I was doing a screen replacement on an iPhone 7 today. Have it a couple 30 second bursts of a hair dryer just to loosen the glue. Put my pry tool in and started to gently work on the bottom left hand side of the phone. I had the screen pretty much pried off when I accidentally hit the power button and the phone turned on, when it turned on I got a message saying that the power button needed servicing and the assistive touch thing came up on the screen. I continued with the repair, everything works perfectly apart from the home button. I have tried it on the old screen, not working there either.
I know logic says I did damage but I have looked and looked at the home button and ribbon cable and cannot see anything wrong with it. All I had done when I got this message was open the phone. I’m not a rookie with either, I have replaced upwards of 100 screens on lots of different iPhones. Am I goosed here?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It’s pretty easy to tear the Home Button flex from the screen. It has a nice 90 degree turn that is ripe for tears. However, as an experienced tech, you would probably be able to spot that pretty easily. I just wonder if you didn’t accidentally damage the actual Home Button and it’s flex when you applied the pry tool. Stuff like that happens even to the best of us ;>).
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Ugh anything is possible I guess, it’s not working for a reason and it’s driving me insane cause I don’t know what it is. I think I’m gonna stop it to my board guy to have a look at it under the microscope to see if he can see any damage anywhere. Painfully annoying, phone is pretty much worthless now.
из
Добавьте свой ответ
Mary Ellen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 61
