Screen is black - can I repair or replace
I have an early 2008 17 inch MacBook Pro with the 1920x1200 Matte Screen. The display is black but the system works fine with an external monitor. Could I just replace the screen or does the screen assembly need to be replaced? I had the spotlights problem for several years on this system which I assume was the fluorescent backlight.
Это хороший вопрос?
Оценка 0
2 Комментариев
@movdqa describe this "the spotlights problem" a bit more.
из
It was bright at the bottom of the screen with round things and the screen was dimmer as you moved to the top. I was able to use it in this mode for a few years. I think that it was common with this model as I've seen other reports of it.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@movdqa check the inverter first. There could be reasons other than a bad LCD display. This video as well as this should work for you
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Michael Moy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 31
