Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342вопросов Показать все
Is iMac11,2 (mid2010 i3 3.06) possible to change the cpu to i7?
Hi all,
I see that there is a lot of mid2010 i5 capable to upgrade to i7, but I can't find any post of i3 3.06 to i5 or i7.
Looking the socket, they are all the same (LGA 1156).
Is that possible ?
I've found this article, but it's about the 27" and not 21".
http://www.hardmac.com/articles/335/page...
cheers
Это хороший вопрос?
Оценка -1
2 Комментариев
Guys, just found a article and the iMac 2011 are made to not work with another parts that were not sold by Apple. In other words, this thing of make upgrades on iMac's are close to stop.
"New iMac Drives Not Meant to Be Replaced, And I Hate It"
http://gigaom.com/apple/imac-drives-not-...
из
@Patrick: Messed up? Yep. Surprising? Hardly. Unfortunately, this doesn't address the original question, which is about the processor. I do see what you meant, however. The thing is, Apple products are generally not designed for modification. The iMac is hardly an exception...bastards. :p
из
Добавить комментарий
4 Ответов
Выбранное решение
From my research, you should be able to upgrade to the processor to the 3.6GHz i5 (680) mentioned in the alternative-configuration spec, but I don't believe it would work for an i7 due to power requirements and a likely lock-out by Apple on the hardware itself.
I hope this helps!
Был ли этот ответ полезен?
Оценка 5
it seems you can only upgrade your imac i3 mid 2010 21,5" to i5 680 processor. I'm looking for other information as I would do this upgrade, but i'm waiting a confirmation about that.
see here:
http://www.everymac.com/systems/apple/im...
Оценка 1
What about the quad core I5-760? Would the same power requirements put a downer on things? I´ve also looked at the dual core I5-680, and for reasons of power requirements, I´m inclined to believe that you simply can´t run a quad-core processor with that logic board.
(I bought the mid2010 base-line iMac three days before the 2011 got released, annoying..)
Оценка 0
I have the same question, so can the imac 11,2 21.5" be upgraded ?? does it work ? has anyone tested it ? all videos are for the 27" model not the 21.5 ".
Оценка 0
Добавьте свой ответ
Patrick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 5,644
