This Audi A6 model received a facelift in 2001 for both sedan and Avant versions. The revised A6 sedan featured a new grille design and different headlights, while also being fitted with a wide range of petrol and diesel engine configurations. Most of these powerplants received a boost in power outputs.
What do you think it could be
my wife turned off the car. the antifreeze poured out of the bottom of the car
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
It sounds like you have a coolant leak somewhere. You’ll need to do some hunting around to find exactly where the leak is. If you’re in the U.S. Harbor Freight has a decent cooling system pressure tester that could help you pinpoint it quicker. If you can let me know exactly where the leak is I might be able to help guide you through the repair. Good luck.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
joelnolting3 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 516
