Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
23вопросов Показать все
Replace keyboard on Samsung Chromebook PRO/Plus
I recently spilled liquid on my Chromebook Pro and some of the keys are no longer working. I tried to remove the keys to see if any residue was causing them to not work but to no avail. Is there a DIY to replacing the entire keyboard?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
This is going to take replacing the entire palmrest, keyboard, track pad assembly for the most painless repair. The assembly usually runs between $50-80 and the repair should take about 30min if you're comfortable with laptop and phone repairs.
Был ли этот ответ полезен?
Оценка 1
You’re better off sending it off to Samsung to deal with this one. Also, isn’t this chromebook quite new? You should check to see if it is still under warranty.
Оценка 0
Unfortunately it's gen 1 purchased right after it's release date and out of warranty. Thanks for the suggestion though.
Оценка 0
Добавьте свой ответ
Joe Dellava будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,026
