Support for musical holiday decorations by Mr. Christmas Inc.
music stop to play, how can I fix?
Hi, can you please tell me where I can see how to fix the music on my christmas triple deck carousel
Это хороший вопрос?
Оценка 0
2 Комментариев
I have no music - turning the volume control does nothing.  Where do I look to make the volume work.  I sound worked , we had to take apart to put a new drive belt on.  The carousel would not turn, but the music did work.
Please advise.
Thank You
из
volume doesn't work at all - no sound what so ever!
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Make sure you are using fresh batteries on your carousel. Also, could you elaborate more on what the problem is? Is the speaker crackling or unclear, or is there no sound at all?
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
Carousel goes around perfectly but has no sound. Have turned up volume and tried different song options but nothing works. No crackling noises.
из
the carousel is electric and there is no sound at all
из
Yes the carousel move freely. We have switch the different songs, move the volume up and down (nothing) and no crakling sounds
из
any suggestions?? needing help
из
Mine is not playing music either. If I play around with the buttons I hear cracking.. maybe a few notes of the song and then it stops.
из
Добавьте свой ответ
yarasalvador2011 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 2,357
