Why is my phone not switching on?
its actually nokia 6.1 plus not nokia 6… its a new phone . I was using it on low battery and then suddenly found a bug on the screen . So I restarted it but it is not switching on now!
someone pleeeeeeaassee help
Это хороший вопрос?
Счет 0
1 Комментарий
My Nokia 6.1plus battery does not charge.
Is there a problem with the charging board?
Is this the charging board Nokia 6.1 plus his original ?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello,
Try pressing the power+volume buttons to hard reset the device in case it doesn’t work please take the phone to the nearest service center to get a closer look at the issue.
Hope this helps….
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Greatly appreciated your advice! It worked. Thought I was sunk ... and looking around for a pro until I read your advice.
из
Добавьте свой ответ
Eeshdeep Singh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 1,197
