Does not turn on ...Can you help?
Just bought Power Mac P4 and It will not come ON ......Can you suggest what I can try????
Это хороший вопрос?
Это хороший вопрос?
I'm assuming you mean a PowerMac G4. Is anything happening--ie any noises, lights and so forth. We really need a little more information to properly help you. Ralph
Был ли этот ответ полезен?
Tough one -- could be just about anything. But the last time I had a computer similar to this conk out on me (it was a B&W G3), I checked all the hard drive connections, unplugging them and replugging them. If I'm remembering correctly, I think I also swapped the PRAM battery with a PRAM battery from a different, working computer. And I may have removed and reseated the RAM. The computer eventually started back up, but I'm not certain exactly which of my various tricks brought it back.
UPDATE: You can find teardown and repair guides for some G4 PowerMacs here: Power Mac
A couple of safety tips, in case you haven't opened a machine like this before -- be sure to unplug the machine before you open it up. Be sure to wear an anti-static strip and/or frequently touch metal while working on the machine to decrease the chance of static electricity frying the machine. And take special care when working inside these machines -- there are some sharp metal edges inside and you don't want to cut yourself.
I agree with mister790--try the things he suggest. If they fail to get you started you may have a bad power supply. Hers a URL to help you with that if needed. Ralph
nothing no sound no light nothing wantmy phone number ? David
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,937
1 Комментарий
Matt, you edited this to a Quicksilver, why?
из mayer
