Why does my compressor take so long to get up to maximum pressure?
It takes several minutes, more than 20, to get up to maximum pressure. Also after a couple of cycles the compressor won’t start again.
Это хороший вопрос?
Это хороший вопрос?
cladoo you did not tell us what you have checked and what exact model your compressor is. I know you picked the device but we just have to be sure. Usually, if an air compressor is taking long to the fill it typically is either a seal problem, gasket failure, or an intake or pressure valve failing. Your “after a couple of cycles the compressor won’t start again “ could also be indicative of an electrical air compressor that is laboring to fill. That could be an issue with the motor/capacitor. If you have a bad run capacitor it would then no longer start. Start by checking on those things and let us know what you find.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 61
За всё время: 6,358
2 Комментариев
Is there oil in the compressor?
из Hive Army
oil less compressor...
из pollytintop
