Why does my Dymo LabelWriter 450 not turn on?
My LabelWriter 450 will just not turn on. I’m not sure what to do.
Это хороший вопрос?
Это хороший вопрос?
Check that your LabelWriter is properly receiving power by making sure the power adapter is plugged in all the way into the back of the device. If that doesn’t work check to make sure that your device is inserted all the way into the wall jack. The power adapter that comes with the LabelWriter ends in a large box, so it is possible that it may have come loose in the wall jack.
Был ли этот ответ полезен?
may be, you do update your windows, then driver printer not work correct, you can update drivers for dymo labelwriter 450 with click download here
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 661
