Repair guides and support for your Philips TV.
243вопросов Показать все
Something wrong with T-Con board?
Recently my TV started showing this dark shadow on one side:
I managed to get it away when fiddling with the left ribbin on the T-Con board, but only for like 5 minutes. This problem returns every time.
What could it be? And is it fixable?
Это хороший вопрос?
Оценка 0
1 Комментарий
Need model number.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Roan de Graaf  that does not look like a T-con error. It looks like a dim light and a fix for that would be a new power board. Of course, there is always a possibility that this is a bad panel. Start with a new power board and see what it does.
Update (11/08/2018)
Odd behavior for a T-con board but if you can resolve it by moving the hasp on the board, consider changing the T-con. I'd purchase one that could be returned just in case it does not resolve the issue.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
No, its definitely not a dim light.. All the backlights are working just fine and when I disconnect the ribbon from the T-Con the screen turns completely white.
I can get it away by opening and closing the latch of the ribbon on the T-Con board multiple times, like sometimes it triggers something to make it right. But that doesn't last long tho.
из
Добавьте свой ответ
Roan de Graaf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 770
