Repair guides and support for a wide range of small engines.
103вопросов Показать все
compression release malfunction on craftsman 24HP Twin?
I have Good fuel, good spark, both intake and exhaust valves function on both cylinders (I removed the valve covers and observed them),  I have good compression on RH cylinder, no compression on LH cylinder.  Engine will not start.  Ideas?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
No compression on LH cylinder sounds like major issue with that cylinder. Cylinder leakdown test may reveal if it is losing compression past valves or piston rings or head gasket. However, most DIYers don’t have a leakdown tester.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Good compression on RH cylinder. None on LH cylinder. I can get a compression tester. Question: with a 2 cylinder and good compression on one cylinder and none in the other, wouldn't it still start? Just run really ragged?
из
Добавьте свой ответ
Harry Laclair будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 76
