Навыки, которые настолько потрясающие, что не вписываются ни в одну категорию.
What is the best glue/adhesive to use on a peeling bodyboard?
I will be going to Mexico for my Thanksgiving break and I was starting to pack things today. I usually bring my bodyboard with me so I can do some bodyboarding in the ocean near the hotel I stay in.
The problem I am facing is that the bottom of the board is peeling away from the rest of the board in one of the corners. See image.
Things I have tried…
  • Gorilla Glue and Krazy Glue; they both dissolve in the salty water of the ocean
  • A hotel employee offered to try some of the glue they have on the corner, it dissolved too. I do not know the brand of the glue they tried.
Keep in mind that if you recommend a certain glue/adhesive it must be able to withstand the salty waters of the ocean.
As a last resort to this problem I will use Flex Tape to tape the board together.
@mayer I will be scarce starting this upcoming week starting Saturday. Hold down the fort for me.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Here’s how to do it, use construction adhesive or liquid nails:
Have a great trip!
Был ли этот ответ полезен?
Счет 1
7 Комментариев:
@mayer Thank you! I will try liquid nails and report back the results once I get back from my vacation (so I can make sure the salty water doesn’t dissolve the adhesive).
из
I bought Flex Glue and glued the board together. Time will tell if it stands up to the ocean or not.
из
I put Flex Glue to the test today and used that bodyboard today. It still holds strong!
из
@ajcooke01 I take it you are back form Mexico
из
@mayer No, I am in Mexico for a week! I will be back in Colorado on Sunday.
из
Показать ещё 2 комментариев
I have a cheap-o board I am going to fix the plastic slick on the bottom with a tube of Liquid Nails - Interior Exterior Extreme Heavy Duty Construction Adhesive.
I will write back in a couple of weeks.
Also, if it is just the rails on the side or a ding in the bottom slick - Eboadyboarding.com recommends just hot glue. https://www.youtube.com/watch?time_conti...
Счет 0
Добавьте свой ответ
[deleted] буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 16
За последние 30 дней: 70
За все время: 10,505
