4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331вопросов Показать все
Buldge on lefthand side of screen
I’m trying to diagnose the problem before I order parts. I have a 5th generation ipod touch. The screen has popped off on the left hand side of the case. I have tried pressing it back into place with no luck. I’ve tried pressing firmly as well- it move freely put nothing clicks into place.
I’m trying to figure out if the issue is the adhesive has gone bad or if it is the plastic clip around the case?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
The battery may be swelling. Swollen batteries can pop trackpads off Mac Laptops and make phone screens bulge like that.
Here is how you can open up the iPod to check if the battery is swelling.
iPod Touch 5th Generation Battery Replacement
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks, I just got a chance to open it up and the battery is swelling.
из
@jlewv I knew it! Dispose of that swollen battery immediately, it’s dangerous and can combust if it keeps swelling...
из
It can also be a slightly bent case. The case can bend out of shape from pressure in pockets or being dropped. If that is the problem, it can often be fixed by being placed under weight (car battery, large water jug, etc.). You can also get a new frame. (Though I’d check on the battery first, as Aaron suggested.)
Оценка 2
1 Комментарий:
Thanks, it was a swollen battery
из
Добавьте свой ответ
Joshua Edwards будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 838
