First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130вопросов Показать все
Replaced screen but it registers false touches
I've replaced my screen twice already and both times, the ipad acts as if I'm touching the screen in various areas when I'm not.
I'm wondering if it has anything to do with the emi tape or possibly the fact that I broke the little plastic tabs that hold the digitizer ribbon cable. Although broken I was still able to get them to lock down the ribbon cable.
I've tried a hard reset and no difference. Help!!!
Это хороший вопрос?
Оценка -1
1 Комментарий
Hi all,
I also had too replace the lcd screen, after that i also had "false touches", I suspect that the touchscreen also is damaged because ithe right corner is see a ligt spot and in that same area i cannot type or if i touch te screen there the ipad won't respond.
brgds,
Steven
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
gilatene, my first instinct says that it is the connection of your digitizer to the logic board. Make sure that it is straight inserted and properly seated and connected. I imagine that the broken clip can cause your digitizer ribbon to not make proper contact. Try to reinsert it and see what you get. Good Luck and let us know how it is going.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
gilatene будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,175
