Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433вопросов Показать все
LCD causing power supply failure
I replaced a power supply that failed. The onboard LED indicators are telling me that everything is functioning until I connect the LCD display power cable. Then the power supply fails and all of the LED’s turn off.
Do I need to replace the display or is there another issue?
From what I’ve read it seems the issue could also be the inverter. I don't know enough about computer hardware to know what the inverter looks like or how to test it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The inverter for the CCFL lamps is part of the front display assembly. Its the same layout as seen here: iMac Intel 24" EMC 2111 Inverter Board Replacement. Apple never offered it as a replacement part. But here’s one source iMac 24" Inverter Board - Mid 07/Early 08 - Recycled
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Julio Acosta будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 52
